i'm using the power supply 2 plus, and i just bought my third modulator, and i have no idea how to connect all the pedals,
Tech 21 samsamp gt2
Ibanes ts9
Boss dimension c
Boss TU2
MXR phase 90
Coloursound wah-wah
Strymon bigsky
Line6 dl4
Digitech whammy
does the power supply 2 plus support all of them or do I need to buy a new one?
Are the Y cables safe for the pedals?
Thanks to all for your help!
Is it possible to connect 3 modules to the power supply 2 plus?
Facciolla1984
Re: Is it possible to connect 3 modules to the power supply 2 plus?
Each of the pedals (including the Whammy but only if it's the Whammy 5, which uses DC power) could be powered from the Pedal Power 2 Plus DC outputs (also, Current Doubler Adapters, part# PPAP would be needed) BUT all pedals can NOT be powered simultaneously.
To power them all simultaneously you would need a supply with more high current capacity, such as any one of these: Pedal Power 4 x 4, Pedal Power Mondo, Pedal Power 3, Pedal Power 3 Plus. Also, with one of these supplies, additional current doubler adapters would not be necessary.
Hope this helps!
Hope this helps!
Cheers,
Ben Resnick
Voodoo Lab - Tech Support
Ben Resnick
