Trying to get my head around creating a new live setup which is gonna be heavy but hopefully very, very ‘plug and play’ which is what I’m looking for.
I have a list of gear and a list of requirements and I’m really hoping someone can lend a hand and explain how things should be wired up and what cables I’ll need. Newish to MIDI but I’ll be able to figure it out once things are actually plugged in correctly I hope.
Gear (all to be housed in one super heavy awesome custom rack with a built in amp head shelf for the Mesa)
Dual Rectifier (3 channel with channel switch jacks on the back)
GCX
Ground Control Pro
Bunch of pedals to sit in the rack drawer (some to go in effects loop, some to go in front of amp) - 1 is midi controllable delay)
Wireless guitar system in the rack
Two Notes Captor X cab IR (mainly for home use at lower volumes through studio monitors but ideally will also use live to send direct signal to FOH)
Morley switchless wah (most annoying part, needs to be in front of amp - at some point may switch to using built in wah of a gmajor with an expression pedal but super addicted to the switchless operation)
Any help appreciated, dumb it down as much as possible
