Powering Line6 HX Effects and GCP
matsnerli
Post by matsnerli »
Hi guys!
I have both a pp2+ and a 4x4. My question is if it is able to power a Line6 HX Effects and a Voodoo Lab GCP on my 4x4?
I have understood that I can power either the Line6 or GCP on the 5 and 6 with a doubler on the pp2+, but is it possible to power both on the 4x4?
Looking forward hearing from you guys!
Rez
Re: Powering Line6 HX Effects and GCP
Post by Rez »
Yes, it is possible to power both with the Pedal Power 4 x 4, setup:
To power the HX Effects with Pedal Power 4 x 4, use two 9VDC high current capacity (400mA) outputs with a HX Current Doubler Cable
To power the Ground Control Pro with Pedal Power 4 x 4, use a 9VDC high current capacity (400mA) output with a 2.1mm/2.5mm Reverse Polarity Barrel Cable, part# PPL6, PPL6-R
Also/FYY, the Pedal Power 2 Plus DC outputs (even 5 and 6) cannot be used to sufficiently power the HX Effects but it can instead be powered from the AC courtesy outlet with its adapter/wall-wart.
Cheers!
Cheers,
Ben Resnick
Voodoo Lab - Tech Support
matsnerli
Post by matsnerli »
Thanks man! You saved this weekend’s gig!
Rez
Post by Rez »
Woo Hoo! :D
Cheers,
Ben Resnick
