DMC Ground Control + Ground Link preset issue
showmesirion
Post by showmesirion »
Hello! I am new to this forum so first post here. Hopefully someone can help!
I am setuping a rig using the DMC-era Ground Control v2.4 + Ground Link + GCX. I want to configure the Ground Link to send CC messages but I can't save or recall the Instant Access Buttons states per GC presets.
Setup:
Bank4 mode
MIDI Device "MPX1" on CH1
Expander: GL on PROGRM mode, CC messages assigned to buttons 1 to 6
Preset 01 sends PC#01 on MIDI CH1
Preset 02 sends PC#01 on MIDI CH1
Preset 11 sends PC#02 on MIDI CH1
Preset 12 sends PC#02 on MIDI CH1
GC transmits both PCs and CCs (MPX1 receives them).
When I select a preset with a PC on CH1 all 6 button's' leds turn on. There is no getting back to a state where I pressed "store" on the GL... What I am missing?
Other weird behavior: the GCX Active Led is always On. It blinks whenever I recall a preset or press any GC or GL buttons. Is this normal?
Thanks in advance for any guidance.
Re: DMC Ground Control + Ground Link preset issue
Sorry to say but this is a symptom of this very old hardware. Both the Original Ground Control and the Ground Link lack the ability to save the state of the buttons when they are re-programmed with MIDI Channel and Controller Number.
The GCX Active LED will stay on when a Ground Control configured to enable the GCX is connected. This is normal.
