http://www.stevemillerband.com
Jacob wanted something that he could use on his solo projects, but could double for things that he could use on tour with Steve Miller and in the studio. Jacob requested that the rig be built out from a custom TheGigRig PRO 8 with an insert between loop 5 and 6 to for a volume pedal to be always active in the signal path no matter how the presets in the PRO 8 were arranged.
Jacob is using various Stratocaster and Telecaster guitars going into Red Plate Amplifiers.
INTERFACE
Standard Vertex Dual Buffer (input buffer and output buffer)
POWER SUPPLY
Voodoo Lab Pedal Power 2+ (with extension cord running out of courtesy outlet for the power supplies with the Hilton Volume Pedal and TheGigRig PRO-8).
ORDER OF PEDALS
INTERFACE (Vertex Input Buffer), TREX Octavius, TheGigRig PRO 8:
Loop 1 - AYA Compressor
Loop 2 - Wampler SLOstortion
Loop 3 - Wampler Plexi Drive
Loop 4 - Creation Audio Labs MK 4.23 Boost
Loop 5 - Hartman Flanger and Empress Tremolo
Insert - (Hilton Volume Pedal with tuner out to Whirlwind Tuner)
Loop 6 - Empress Vintage Modified Superdelay
INTERFACE (Vertex Output Buffer)
