Hi! I just bought second hand Superfuzz and I'm confused. I don't know if it works correctly or not. Is the "attack" knob supposed to act like gain control in a tube amp and "volume" like main volume. So if I crank the volume knob all the way up and attack all the way down I get no sound. Is this the way it should function?
Thanks and greetings from Finland.
Superfuzz logic
Re: Superfuzz logic
It is normal for the Superfuzz to act this way. Attack all the way down kills the signal.
Re: Superfuzz logic
Thanks John, this clears things out a lot! Keep up the good work!
Re: Superfuzz logic
Seems like it's not about the logic... I've got all knobs at full and I only get really weak fart-like sound.. What could be the problem?
Re: Superfuzz logic
Wait... it took you 6 months to turn the knob from all the way down to all the way up?
With all the knobs cranked the Superfuzz should certainly not sound thin.
I know you're quite a ways away but we can offer to take a look at it for you if you'd like to send it back to us for an inspection/repair... if you'd like to d that, write to info@voodoolab.com and be sure to mention this thread and that I sent you.
Re: Superfuzz logic
Well the pedal did work okay for 6 months
I paid about 20 bucks for the pedal so it's not worth sending it over...though it's a good sounding pedal when it works
Should I maybe contact some DIY-pedal forum or can you make any suggestions what could be broken without seeing it?
I've got some diy-electronics knowhow so if it's simple as desoldering and soldering something, I can figure it out myself
Thanks anyway
Thanks anyway
Re: Superfuzz logic
Is the problem only when all the knobs are cranked or is it now also not working in other positions?
Maybe check for broken pots would be a first guess without seeing it myself.
