In regard to the SW build, and in regard to overwriting some of those patches: Is it necessary to perform a MIDI dump in order to transfer new rig names and utilized rig FX info to a Ground Control Pro?
In the SW version, the top 8 buttons are mapped to the 8 11R FX buttons. I know that you can manually edit the LED state by simply entering the edit mode on the GCP, switching the LED and then exit the edit mode and 'save', but I assume that a MIDI dump would overwrite the current LED states.
Is this correct? If so, please make a recommendation on:
A great MIDI editor
How to retrieve the current MIDI states from the 11R
Thanks!
Steve
Search found 1 match
- Fri Mar 07, 2014 9:42 am
- Forum: Racks, Switching Systems and MIDI
- Topic: Ground Control Pro +Eleven rack sweetwater patch memory dump
