Phew! The madness stops! I thought I was losing my mind?!?! No worries though...I'm always thankful for all the help you guys provide on all your products. Plus, I don't always explain things the bestJohnClark wrote:I see I started the confusion earlier... oops! Getting out my trusty internet white-out!
The Control Switcher will always apply power to pins 1 and 3 on its MIDI In jack.
The jumpers only connect or disconnect the "phantom power" pins on the MIDI Out jack.
Because you want to phantom power your Control Switcher via its MIDI Out, you will have to set the jumpers so they are on both pins of the header. (didn't you have a picture of this here before?... it showed the jumpers connected as they should be to allow for phantom power thru)
You can either use a cable that does not wire pins 1 and 3, cut pins 1 and 3 out of the cable, or ask the manufacturer of whatever other piece of gear you are connecting to the MIDI In on the Control Switcher if they use pins 1 and 3 for anything.
Yes, I had a photo on here. Maybe I removed it in all my madness, but I don't remember. I thought you removed it. ARGH!! There must be ghosts in this house....
