Search found 10 matches
by nikbia
Fri Oct 19, 2012 3:46 am
Forum: Racks, Switching Systems and MIDI
Topic: Mesa Mark V
Re: Mesa Mark V
by nikbia
Fri Oct 19, 2012 3:19 am
Topic: Mesa Mark V
Mesa Mark V
Hi boys,
Is possible connect Mesa Mark V to GCX for to control midi?
thanks :ugeek:
by nikbia
Wed Jan 18, 2012 2:59 am
Forum: Audio and Video Clips
Topic: What do you think of this sound?
Hi boys,
What do you think?
http://www.youtube.com/watch?v=affeEt5UMFE
thanks!
by nikbia
Sat Oct 01, 2011 9:00 am
Topic: connect two amplifier
Re: connect two amplifier
What do you think? The cable is correct?
Thanks
5.
in: 1 Cable Y
Send: IN MESA DC-5
6.
in: 2 Cable Y
Send IN JCM 2000
by nikbia
Wed Sep 28, 2011 10:39 pm
Do you want only one amp at a time or will you need to play through both amps at once?
-Possibly both amps.
Does the Intellifex need to be used in the effects loop on both amps?
-sure, possibly both amps.
thanks again!!!
by nikbia
Wed Sep 28, 2011 2:15 pm
Hi,
I have the GCP and GCX.
I attach the pedals and the heads of amplifier:
Guitar>Loop1 dyna comp>Loop2 phase 90 >Loop3 TS-9 >Loop4 head jcm2000 dsl100 >Loop5 head mesa dc-5 > Loop6 ch jcm 2000 > Loop7 ch dc-5 > Loop8 Intellifex on-line (send return) > 4x12
how can I connect everything? and can i use this Expression Pedal 1 Volume Pedal BOSS FV-500H connect to the GCX?
Thanks
by nikbia
Mon Nov 29, 2010 4:56 am
Topic: Question switching amp on gcx
Hello
I have two amps (mesa dc-5 and Marshall JCM2000 dsl) to be controlled by GCX.
I would like to manage the pre and power amps separately.
How can I do?
Thanks.
P.S.: Where can I find the empty image inputs writes for GCX?
by nikbia
Mon Oct 25, 2010 12:05 pm
Topic: How to connect intellifex on gcx MIDI
Re: How to connect intellifex on gcx MIDI
Great ....
Resolved, disconnect and connect the cable!
Thank you for everything!
by nikbia
Mon Oct 25, 2010 11:36 am
The connection MIDI is correctaly
The number MIDI is 15
SETUP MODE (ground control)
1.Intellif/15
But when enter in program mode and change the preset of intellifx it isn't responding.
If connect the ground control on MIDI IN the intellifex working properly!!!
Where is the problem?
by nikbia
Sun Oct 24, 2010 11:23 pm
Hi everyone
My question is:
If possible change the preset of intellifex on ground controll (NOT PRO).
My setup is:
1
in - guitar
send mxr dynacomp in
return mxr dycomp out
out - 2
in - 2
send mxr phase90 in
return mxr phase90 out
out - 3
in - 3
send ts808 in
return ts808 out
out - 4
in - 4
send ts9 in
return ts9 out
out - 5
in - 5
send ocd in
return ocd out
out - in MESA DC-5
out - 6 change canal DC-5
out - 7 change EQ DC-5
in - 8 Send DC- 5
send - intellifex in
return - intellifex out
out - return DC-5
With ground control works everything except the change presets of intellix
thanks all and sorry for my bad english ;)
