PX8 Plus loop "insert"
pg7
Post by pg7 » Sun Apr 29, 2018 6:41 am
PX8-PLUS insert loop : 1.what are the common options of use please expand!!! Very poor instructions in manual other than "it interrupts the chain between loop 6 & 7 " whatever that means. I just purchased a unit and would like to plan my pedalboard layout and try different staightforward options !.
The "mystic" instructions makes me feel I should be an "initiate" with switching systems. I am not , this my first switcher and will most likely be for a long time given the outstanding quality of your products
Re: PX8 Plus loop "insert"
Post by JohnClark » Mon Apr 30, 2018 11:39 am
The Insert provides a break in the series chain of loops. This allows you to use Loops 1-6 separately from Loops 7 & 8.
It might help to think of the Send as "Loop 6 Out" and the Return as "Loop 7 In".
This is most often used to facilitate running some pedals in front of an amp using Loop 1-6 while using Loops 7 & 8 for pedals in the Effects Loop of the amp.
Another use is to put a Volume Pedal in the Insert so it will be routed after any Overdrive or Fuzz effects.
What effects will you be running and how would you like them routed?
pg7
Post by pg7 » Tue May 01, 2018 3:11 pm
Thank you for the response.
I am going to try both options and see.
Not yet received the unit and board .
I would like to make contact and pick your brain again for details.
Hope not to be too much of a bother. Thanks
I will be running a variety of Fuzz pedals , overdrive , univibe , compressor and a combo delay/reverb/rumble drive. Volume pedal and expression pedals available but I don't know how to best utilize them.
