Phantom Power
Fryettefiend
Phantom Power
Post by Fryettefiend » Sat Mar 03, 2018 8:35 am
Hi, I was wondering if you can power a Fractal mfc-1 footcontroller, using a standard midi cable, like it works for the GCP?
If not a standard midi cable, can I get a special one Made?
Fryette Ultra Lead head
Fryette fat bottom 4x12 slant greenbacks
Fryette fat bottom 4x12 Eminence
Zakk Wylde wah
GCX audio switcher
RJM mini amp gizmo
GCX ground control pro
Rocktron intellifex online
Rocktron intellipitch
ISP Decimator
Re: Phantom Power
Post by JohnClark » Mon Mar 05, 2018 12:42 pm
The MFC-101 will accept Phantom Power on Pins 6 and 7 of its MIDI Out jack. What will you be using to provide Phantom Power?
If its a GCX, then you will need a custom cable or interface. The GCX provides Phantom Power on pins 1 and 3. You will also need a higher output power supply (9VAC and minimum 1.5A) for the GCX to handle the larger current demand of the MFC-101.
Also, just to be sure, you do have the MFC-101, not "MFC-1", right? ;)
p.s. If you are also using an Axe-FX I would suggest having it provide the Phantom Power before anything else.
Fryettefiend
Re: Phantom Power
Post by Fryettefiend » Fri Mar 09, 2018 5:31 pm
Yeah I was wanting to use the GCX audio switcher to power it.
Where could I get a custom cable made, and how do up the power to what the MFC 101 needs.
I also have a Rocktron intellipitch, intellifex online,and a power station, and a pp2 in my rack.
I wondered if the Rocktron gear could power it properly w/ one of the 7 pin cables?
Zakk Wylde wah
GCX audio switcher
RJM mini amp gizmo
ISP Decimator
Re: Phantom Power
Post by JohnClark » Tue Mar 13, 2018 3:04 pm
A 7 Pin Cable from one of the Rocktron processors would do the trick. You will need to provide power to the Phantom Power In jack on whichever processor you use. I believe your Power Station will work for this using one of the 9VAC outputs.
Fryettefiend
Re: Phantom Power
Post by Fryettefiend » Wed Mar 14, 2018 8:48 am
Awesome thank you !!!!
Zakk Wylde wah
GCX audio switcher
RJM mini amp gizmo
ISP Decimator
