Pedal power 2+ and outlet with ciocks
pascalgr
Post by pascalgr » Sun Feb 18, 2018 9:50 am
Hi
I have the power 2+ (export 220v) and ciocks *
Can I power the ciocks with the output outlet of the power 2 plus ?
Pascal
Re: Pedal power 2+ and outlet with ciocks
Post by JohnClark » Tue Feb 20, 2018 10:40 am
As long as your Cioks "HooHah Power" accepts 220V, then yes, you can power it from the Courtesy Outlet on the Pedal Power 2+.
You will need a power cord that goes from an IEC C14 to an IEC C5. Here is an example I found on Amazon UK... https://www.amazon.co.uk/kenable-Clover ... B0079I48E0
pascalgr
Post by pascalgr » Tue Feb 20, 2018 12:09 pm
My ciocks pus...y accept 220v
Do you think she's less than 200 watts? (Limit of the courtesy output)
The total amperage is 1.6A
Post by JohnClark » Tue Feb 20, 2018 1:32 pm
A valid question, however that 1.6A is in reference to the 9V outputs... even at full load, the "HooHah Power" will consume less than 20 Watts from the Mains power.
