Pedal Power 2 plus w/ Echolution 2 ultra pro
zlov137
Post by zlov137 » Wed Dec 20, 2017 7:45 pm
So the Echolution2 ultra pro needs 18v. I am curious if I need to buy a new connector, and if I do where would I plug it into. Right now I'm using the courtesy outlet to power it. Would it go into the l6, or sag, or aca.
Also, you can run 9v pedals from all the slots correct? The guy at the store wasn't very helpful, he just said there are 8 isolated power things and you can plug 8 pedals into it.
Re: Pedal Power 2 plus w/ Echolution 2 ultra pro
Post by JohnClark » Thu Dec 21, 2017 11:03 am
The Echolution 2 Ultra Pro can be powered from any two outputs with their corresponding DIP switches set to Normal using a Voltage Doubler Adapter together with any of the included standard barrel cables.
The Outputs on a Pedal Power 2+ when switched to Normal each provide 9VDC.
Sorry you had a less than helpful purchase experience! What are the other pedals you will be using?
