Pedal power 4x4 24v & 12v
Jonnelaakso
Post by Jonnelaakso » Mon Aug 14, 2017 12:49 pm
Hello! First time poster here.
I have a question about powering ehx q tron plus which requires 24v power and t rex replica 12v with pp 4x4.
Can I split one 12dc out and connect voltage doubler adapter to first plug of y adapter and other end of v doubler to free 12dc out to power qtron. Then connect replica in to free plug of y adapter to get 12dc?
Hope you understand what I'm after. Thx
Re: Pedal power 4x4 24v & 12v
Post by JohnClark » Mon Aug 14, 2017 5:49 pm
I am not too sure this will work. Since the Output Splitter has one side ground lifted I am unsure what the ground reference will be for the pedal plugged into that leg.
If you do want to try it out, the Q-tron would have to be plugged into the leg of the Output Splitter with the white stripe, and the audio cables would have to be in place for it to power up.
