HELP about DITTO TC ELECTRONICS wiht Power 2 plus!
GRstrat
Post by GRstrat » Tue Feb 07, 2017 6:52 am
Which output i should use from Power 2 plus to use correctly the DITTO by Tc electronics?
Now in the output 1, i can hear some hiss when i start looping....
Re: HELP about DITTO TC ELECTRONICS wiht Power 2 plus!
Post by JohnClark » Tue Feb 07, 2017 11:42 am
Are you sharing this output with any other pedals? Does the Ditto not do the same thing when powered from a different outlet or different power supply?
The Ditto, Stereo Ditto, and Ditto X2 should each be able to be powered from any output on a Pedal Power 2+ with the corresponding DIP switch set to Normal.
The Ditto X4 should be powered using output 5 or 6 with the corresponding DIP switch set to Normal.
Let us know what you can!
