footwhich ground control pro
teleted
Post by teleted » Wed Feb 01, 2017 2:24 am
what size socket do I need to tighten up footwitch :D
Re: footwhich ground control pro
Post by JohnClark » Wed Feb 01, 2017 10:48 am
The one that fits, of course ;)
We use a 9/16" driver here, but a 14mm should also fit.
The nut is rather thin so make sure the socket you use has a more flat face profile. A socket out of a cheap set I just tried is dished so much that it doesn't make solid contact with the nut.
