Routing Help
glebreck
Routing Help
Post by glebreck » Fri Oct 30, 2009 10:19 am
With my GCX I have a GMajor2, BBE Sonic maximizer (rack), and a ISP Decimator Pedal(noisegate).
What order should they be in?
thanks!
Re: Routing Help
Post by JohnClark » Fri Oct 30, 2009 10:42 am
That is entirely up to you, but I would run the G-Major last in the chain. It isn't a noise source, the time based effects won't get chopped by the gate, and there is no need to "sonically maximize" the effected signal in my opinion.
glebreck
Re: Routing Help
Post by glebreck » Fri Oct 30, 2009 11:42 am
So basically your saying...
ISP--->BBE--->G Major 2 correct?
Re: Routing Help
Post by JohnClark » Fri Oct 30, 2009 3:44 pm
I'm saying run the G-Major 2 last in the chain, I doubt it matters what order the other two are in as long as they are before the processor. You don't need to gate the BBE and you can't really maximize a gate sonically.
