Should all my pedals be switched to "normal"?
ForestGnome
Post by ForestGnome » Mon Aug 29, 2016 12:46 am
Hi all, I am trying to power 7 pedals using the Pedal Power 2 Plus:
Korg Pitchblack Chromatic Tuner
Cry Baby Wah (GCB95)
Xotic EP Booster
Electro-Harmonix Big Muff Dostortion
Electro Harmonix Soul Food Distortion
MXR Custom Badass '78 Distorion
Danelectro Echo/Delay
Should the setting be switched to "normal" on all of these?
I know that some pedals require you to plug them in to specific outputs and that some require currant doubling cables. I am curious, do any of my pedals require that? I am assuming that they are all "normal" 9v pedals and that there aren't any exceptions with what I have but I wanted to make sure.
Thank you!
Re: Should all my pedals be switched to "normal"?
Post by JohnClark » Mon Aug 29, 2016 10:14 am
Each of these pedals can be powered from any Output with the corresponding DIP Switch set to the Normal position using one of the included standard all black barrel cables.
ForestGnome
Post by ForestGnome » Mon Aug 29, 2016 11:10 am
Thanks a lot, yes it does!
