PP2+ T-Rex Replica
monk
PP2+ T-Rex Replica
Post by monk » Thu May 06, 2010 10:41 am
Can I use output 1+2 with the dip switches in the on position to power a T-Rex Replica. I´ll use a current doubler cable. It´s 12 volt ac or dc but I´m not sure how many mA it needs.
Re: PP2+ T-Rex Replica
Post by JohnClark » Thu May 06, 2010 11:16 am
That is one way to do it, however the Replica can be powered directly from either output 5 or 6 on a Pedal Power 2+ with the DIP switch set away from Normal with no special cable required.
monk
Post by monk » Thu May 06, 2010 12:02 pm
Thanks. I´m using it with output 5 now but I want to use output 5 and 6 with a Diamond Memory Lane.
ninzanstudio
Post by ninzanstudio » Fri May 07, 2010 8:31 am
Here's some addt'l info I found: http://www.analogman.com/trex.htm
