PX-8 Plus Insert Loop
otraynor
Post by otraynor » Thu Nov 14, 2019 8:11 am
What is the primary use for the insert loop on the PX-8 Plus? Can I use it essentially as a 9th pedal loop that can be programmed like the other loops in preset mode?
Thanks, Oscar
Re: PX-8 Plus Insert Loop
Post by JohnClark » Thu Nov 14, 2019 10:41 am
The Insert does not function like another loop, it is simply a split between Loops 6 and 7. This can be used to connect a Volume Pedal so it is after any overdrives or to break up the loops to route Loops 1-6 to the front of an amp and have Loops 7 and 8 in the Effects Loop... those are the common uses anyway.
What are the effects you would be looking to use?
