4x4 + x4 expander under PT2?
nhirst
Post by nhirst » Thu Nov 07, 2019 3:48 pm
Posted as a hijack to an older post too but figured better to start a new one.
I own a 4x4 which is fitted under a Pedaltrain PT2 using VL brackets. I am considering a x4 extension but:
- will it also fit under the PT2, and if so how? Velcro? An additional bracket?
- is the x4 expander the best option, vs the x4 full (which I noticed was recommended to expand a +2)?
Nick
Re: 4x4 + x4 expander under PT2?
Post by Rez » Fri Nov 08, 2019 7:01 pm
X4 would simply mount with its included Dual Lock mounting tape. And, I expect it should fit.
If you power X4 from a Pedal Power 4x4 12VDC output, X4 will have a total capacity of 400mA. As long as that is sufficient for what you need to power, then it should work just fine.
If you get X4 with its 12VDC power supply, it will have a 1000mA capacity. Thus, I typically recommend getting it with the adapter too... just in case.
nhirst
Post by nhirst » Sun Nov 10, 2019 5:17 pm
Thanks for your reply. I’d already gone ahead and ordered a x4 - think it’s perfect for what I need. 4x4 can do my two hungry digital pedals.
Cheers.
Post by Rez » Mon Nov 11, 2019 10:55 am
Right on!
