Pedal Power 2 + X4 expander + Pedaltrain P2 ?
gottabefunky
Post by gottabefunky » Fri Sep 20, 2019 10:34 am
Does the X4 expander work with a Pedal Power 2+, and will they both fit under a Pedaltrain P2 board?
Re: Pedal Power 2 + X4 expander + Pedaltrain P2 ?
Post by JohnClark » Fri Sep 20, 2019 12:14 pm
With the Pedal Power 2+ we recommend getting the full X4 and using the included power adapter connected to the Courtesy Outlet on the rear of the Pedal Power 2+. All of this will absolutely fit under a Pedal Train P2, ni problem!
p.s. The difference between the full X4 and the X4 "Expander Kit" is that the Expander Kit does not include a mains voltage power adapter.
nhirst
Post by nhirst » Thu Nov 07, 2019 5:20 am
Hijacking this with a similar question. I have a 4x4 already * under a PT2 with mounting brackets. Considering a x4 expander:
- what’s the best way to mount it under a PT2? Velcro or additional brackets?
- do you recommend full x4 or expander?
Ta!
