Old Voodoo Lab power supply
Malapp10
Post by Malapp10 » Tue May 21, 2019 7:53 pm
Hello people and thank you for having me on this forum. I am a long time Voodoo Lab power supply user. I was digging through some equipment and came across a power supply I forgot I have. All it says on the top is Voodoo Lab Pedal Power. It has 8 outputs and I am trying to figure out what the output of these guys are. Unfortunately, my multimeter broke and so all I have is a perfect power supply for a small board that will have four pedals but they all require all require 200ma. I tried searching for the owners manual but came up dry, if someone could help me with this I would deeply appreciate it.
Re: Old Voodoo Lab power supply
Post by Rez » Wed May 22, 2019 9:24 am
Specification for Pedal Power (original/earliest model):
With the DIP switch in the ON position (away from the number), all 8 outputs supply 9VDC @ 80mA.
With the DIP switch in the OFF position (towards the number), all 8 outputs supply 12.3 VDC @ a little less than 80mA.
