PP2+ DIP Switches
ctc
PP2+ DIP Switches
Post by ctc » Mon May 13, 2019 7:18 pm
Can anyone please tell me what the PP2+ DIP Switches do? The manual talks about leaving them in the normal position, or away from normal, but it doesn't say what away from normal does. Any ideas?
Re: PP2+ DIP Switches
Post by Rez » Tue May 14, 2019 10:13 am
Pedal Power 2 Plus DIP switch function:
Setting any DIP switches 1-8 to NORMAL/9V will put the corresponding output 1-8 into its 9VDC setting.
Setting any DIP switches 1-6 to away from NORMAL will put the corresponding output 1-6 into its 12VDC setting.
Setting any DIP switches 7-8 to away from NORMAL will activate the SAG dial* for the corresponding output 7-8.
*Activating the SAG dial allows you to simulate a dying battery by dialing the voltage down from 9V (fully clockwise) to about 4.5 volts (fully counterclockwise).
