Powering Boss MS3
mbman
Powering Boss MS3
Post by mbman » Thu Jan 18, 2018 10:21 am
Can I use my PP2+ to power a Boss MS3 and a Shure GLXD receiver?
TIA
BC Rich PRS and Jackson guitars
Diezel Koch Marshall and VoX amps
Rocktron Lexicon and Boss effects
Re: Powering Boss MS3
Post by JohnClark » Thu Jan 18, 2018 5:37 pm
The MS-3 draws close to 300mA so it will need a Current Doubler Adapter (the one with the Green end) connected to Output 5 or 6 and any other output with both corresponding DIP Switches set to Normal.
The GLXD can be powered from output 5 or 6 and the corresponding DIP switch can actually be set either direction.
swylbilly
Post by swylbilly » Fri Feb 16, 2018 4:42 pm
JohnClark wrote:The MS-3 draws close to 300mA so it will need a Current Doubler Adapter (the one with the Green end) connected to Output 5 or 6 and any other output with both corresponding DIP Switches set to Normal.
Hi John, I also have an MS-3, I'm using a pedal power Mondo. Would I be able to power the MS-3 with one of the 9V 400Ma outs? Thanks
Post by JohnClark » Tue Feb 20, 2018 10:43 am
swylbilly wrote:Hi John, I also have an MS-3, I'm using a pedal power Mondo. Would I be able to power the MS-3 with one of the 9V 400Ma outs? Thanks
No problem to use a single 9V/400mA Output for powering the MS-3.
