GPC Instant Button and Expression Pedal
pezi1707
Post by pezi1707 » Mon Jan 15, 2018 8:36 am
i wan't to control the Wah effect of my Fractal Audio FX8 with my GPC.
I connected the Wah with an instant button on my GPC an connected the
Expression Pedal to the GPC. I also did the Setup of the Expression Pedal in the GPC-Setup-Menue.
If I press the instant button the Wah turns on but the expression pedal doesn't work.
What I'm doing wrong.
Help appriciate.
Re: GPC Instant Button and Expression Pedal
Post by JohnClark » Thu Jan 18, 2018 3:18 pm
The Expression Pedals function is set in the Ground Control Pro presets. This is where you set which MIDI Device you want the Expression Pedal to control and what Control Change number it should use.
pezi1707
Post by pezi1707 » Fri Jan 19, 2018 1:47 am
Hi John,
thank yo so much, I'll try it.
