Current Doubler on the Pedal Power 4x4
Joris
Post by Joris » Fri Oct 20, 2017 10:48 am
I have a Kingsley Page and Harlot ...each need 800mA 9V.
Can I use 2 current doublers on 1 4x4 power block ( on the 4 high current outputs 9V, 400mA)
Thx !
Re: Current Doubler on the Pedal Power 4x4
Post by JohnClark » Fri Oct 20, 2017 11:58 am
The actual current draw for each of these pedals is under 500mA. You can use one 9V High Current output combined with any other 9V Output using a Current Doubler Adapter (the one with the Green end) on a 4x4 to power each one. No problem running two at the same time... in fact you could run four of them if you wanted ;)
Joris
Post by Joris » Fri Oct 20, 2017 2:26 pm
JohnClark wrote:The actual current draw for each of these pedals is under 500mA. You can use one 9V High Current output combined with any other 9V Output using a Current Doubler Adapter (the one with the Green end) on a 4x4 to power each one. No problem running two at the same time... in fact you could run four of them if you wanted ;)
very helpful indeed !
Thank you.
Joris, Belgium
