Hex switcher question
claxor
Post by claxor » Wed Sep 27, 2017 9:10 pm
I just bought a rack shelf made for the Hex switcher, and it didn't come with screws to attach the Hex switcher to the VL shelf made for it.
Where are the screws, or how do I attach the Hex to this rack shelf?
Re: Hex switcher question
Post by JohnClark » Thu Sep 28, 2017 9:48 am
You could say that the screws came with the HEX ;)
The HEX mounts to the HEX Rackmount Bracket using the two #2 Phillips Head screws along the front edge of the bottom of the HEX chassis. Pull them out of the HEX, then set set the HEX on the bracket aligned over the holes in the bracket, then put the screws thru the bracket and into the HEX.
Let us know if you run into any troubles!
claxor
Post by claxor » Thu Sep 28, 2017 10:07 am
Ok, I assumed so. Thanks
