It is currently Sat Jun 23, 2018 10:33 pm
 Post subject: PX8 Plus
PostPosted: Fri May 26, 2017 2:02 pm
How do I do to get my Boss DD3 Delay in the FX loop?
 Post subject: Re: PX8 Plus
PostPosted: Fri May 26, 2017 2:21 pm
Assuming you are referring to the FX Loop on an amplifier, you would use the Insert jacks on the PX-8 Plus to separate Loop 1-6 from Loops 7 and 8.
1. Guitar to PX-8 Plus Input.
2. Insert Send to Instrument Input on your amplifier.
3. FX Send from your amplifier to PX-8 Plus Insert Return.
4. PX-8 Plus Output to FX Return on your amplifier.
Pedals connected to PX-8 Plus Loops 1-6 will be routed to the front of the amplifier. Pedals connected to PX-8 Plus Loops 7 and 8 will be routed to the FX Loop on the amplifier.
PostPosted: Fri May 26, 2017 2:46 pm
Thanks, now it's perfect :P
PostPosted: Tue Jun 06, 2017 7:18 pm
would it work in reverse also. say i have more effects in the FX loop than i run in the front. could i run send into the "input" and then the return into the insert send?(running those effects 1-6) then run guitar into insert return then run the wah and distortion into loops 7 &8?
thanks
PostPosted: Tue Jun 06, 2017 7:54 pm
thanks
Should work just fine!
1. Guitar to PX-8 Plus Return.
2. PX-8 Plus Output to Instrument Input on your amp.
3. FX Send from your amp to PX-8 Plus Input.
4. PX-8 Plus Send to FX Return on your amp.
Pedals connected to PX-8 Plus Loops 7 and 8 will be routed to the front of the amplifier. Pedals connected to PX-8 Plus Loops 1 - 6 will be routed to the FX Loop on the amplifier.
Good luck!
