It is currently Mon Jul 23, 2018 8:38 am
 Post subject: Control Switcher and Harley Benton fxl8 pro
PostPosted: Fri May 12, 2017 12:04 pm
Hello my friends!
I have an HB Fxl8 pro connected to the control Switcher via Midi... but can't get it to work.... I already send PC and CC messages but it memorises the last configuration for all the banks..
what iam i doing wrong?
i used to have the control switcher connected to a line6 M13 and everything was working fine.. but with this loop control i am not able to make it work.. Help please!!!
here is the manual for the Harley Benton Fxl8 Pro:
https://images.thomann.de/pics/atg/atgd ... online.pdf
 Post subject: Re: Control Switcher and Harley Benton fxl8 pro
PostPosted: Fri May 12, 2017 12:28 pm
Is the Control Switcher responding at all?
Does your Control Switcher have the Black Buttons, or the Red Buttons?
Is there any other MIDI device connected to this controller?
PostPosted: Fri May 12, 2017 1:09 pm
Hi John!!
Theres no other midi connected.. just midi out from Fxl8 to midi in Control switcher...
This one as black buttons..
As i press, let's say, bank D on Fxl8 and save a channel change in the Control switcher, it saves, but when i go to another bank the control switchs stay in that same configuration... if i save a new configuration with no amp channel switch and go back to D, my saved configuration was gone... i assume its getting the same midi note every time i press a switch in fxl8...
I do not understand much of midi programming ... I must be doing something wrong.
PostPosted: Fri May 12, 2017 1:58 pm
Yea, it would appear that your controller is sending the same Program Change with each preset... it looks like you'll need to check the programming there.
I took a look at the manual you've linked and have to admit that without the unit in front of me I am having a hard time myself following what it is saying about how to set Program Changes :oops:
PostPosted: Sat May 13, 2017 4:40 am
Yeph!!
I will give it a try today to see if i can manage that.. the thing is, it sends two program changes and two cc.. maybe this is the problem.. it conflitcts... i will try to put the second PC in another midi channel to see if that works. :idea: :idea:
i will let you know i it goes...
Thanks John! ;)
PostPosted: Mon May 15, 2017 6:50 am
Hi!
I have good news!!
The problem was really a conflict between the two midi messages he was sending ... disabling one solved the problem !! :P :P
PostPosted: Sat Oct 07, 2017 3:34 pm
I have the same problem, I am using the HB FXL8 with a Marshall 6101 which has midi channel switching.
How did you disable one of the midi channels on the FXL8?
This is very frustrating!
