Wow! That is quite the list of pedals!
The Mimiq, G-String 2, MXR Analog Chorus, 5150 Overdrive, Phase 90, PS-6, DD-7, SD-1, and what I assume is actually a Boss CE-5 (not an MXR CE-5
) can each be powered from any output to the right with the corresponding DIP switch set to Normal, or any 9V output to the left.
The CS-3 can be powered from any of the four ACA outputs with the corresponding DIP switch set away from Normal.
The KFK-1 and EVH Flanger can each be powered using a
Voltage Doubler Adapter (the one at the top of the page) connected to any two outputs to the right with the coresponding DIP switches set to Normal or any two 9V outputs to the left.
The El Capistan, and what I assume is the EP-103, can each be powered from either of the 250mA outputs to the right with the corresponding DIP switch set to Normal or any 9V output to the left.
The EP Booster and Pinnacle Deluxe v2 both accept 9-18v and can each be powered from any output on the Mondo regardless of the DIP switch setting.
Now the problem you will run into here is that you have way more pedals than available outputs. You can gang pairs of pedals up on a single output using our
Output Splitter Adapter (the one at the bottom of the page) but you may need to experiment with which pedals work well together. Pairing up low current draw pedals is the best place to start. Alternatively, you may want to add a second power supply to keep everything isolated... an ISO-5 would be a good fit here.
