VOLTAGE CHANGE
florchiza
VOLTAGE CHANGE
Post by florchiza » Mon Jan 16, 2017 4:55 pm
Hello , i have to bring the voltage from 220V to 120V , this thing will work?
Sin título.jpg (98.85 KiB) Viewed 1267 times
Re: VOLTAGE CHANGE
Post by JohnClark » Wed Jan 18, 2017 9:18 am
That should be fine.
florchiza
Re: VOLTAGE CHANGE
Post by florchiza » Wed Jan 18, 2017 5:09 pm
For a voodoolab plus 2? , it should work with no problem ?
Re: VOLTAGE CHANGE
Post by JohnClark » Wed Jan 18, 2017 6:49 pm
A fully loaded Pedal Power 2+ will consume less than 20 Watts. If you will be powering anything from the Courtesy Outlet add its Wattage rating to to find your minimum need.
The step down you show is rated for 50 Watts.
