It is currently Sat Jun 23, 2018 10:39 pm
 Post subject: Pedal Power 2 Plus and ToneBone PZ Pre
PostPosted: Mon Jan 19, 2015 4:31 pm
Is there are way to use the Pedal Power 2 Plus to power a 15VDC 400mA Tonebone PZ Pre acoustic preamp pedal?
 Post subject: Re: Pedal Power 2 Plus and ToneBone PZ Pre
PostPosted: Wed Jan 28, 2015 6:09 pm
You can use the supplied adapter connected to the Courtesy Outlet on the back of the Pedal Power, but none of the front panel outputs will support 15V.
PostPosted: Sun Aug 14, 2016 1:23 am
You can use a cable with a 2.1mm right angle and 2.5mm (red) right angle barrel connector and reverse (center positive) polarity designed to power Line 6 DL4/MM4 digital modeling pedals, Eventide Factor, some Electro-Harmonix and Voodoo Lab Pedal Switcher and Control Switcher. You have to run it through the L6 connector on the Voodoo Lab which changes it from regulated 9V to unregulated. I tried it and it worked great and the cable is only $3.50. You can also purchase a stagebug made by Radial for $99 and run two 9V outputs into the stagebug. As long as there is no danger in damaging your PZ-Pre I see no reason not to use the red chord. I can't find any info online that says it's safe though.
PostPosted: Mon Aug 15, 2016 12:57 pm
viewtopic.php?f=7&t=7032
