It is currently Mon Jul 23, 2018 12:31 am
 Post subject: Best-Tronics Pro Audio // 48" Flat Fractal System Pedalboard
PostPosted: Sat Mar 12, 2016 9:21 am
We wired up a rather large pedalboard recently for a customer. The board was for controlling their Fractal Audio Axe-FX system.
The additional effects on the board (Rocktron Banshee TB, DigiTech Whammy, and Morley/Ebtech Bad Horsie) are running to the front of the Axe. Due to the Whammy and Bad Horsie not being true bypass, we added two AmericanLoopers.com units in order to make this happen.
The MFC is obviously for controlling the Axe-FX and the Mission Engineering, Inc. Pigtronix Dual expression pedal is connected for any expression programmed per patch.
Everything is powered by the wonderful Voodoo Lab ISO-5 and AC. While being rather large, the board consolidated everything to one board. The installation of the rear panel on the doghouse of the pedalboard allowed for an easy setup and teardown. The loom just plugs into the designated ports and it is good to go!
http://www.btpa.com
Professional Audio Cables & Rig/Pedalboard Integration
100% Custom - 100% Made in the USA
