One MONDO to power all 15 Pedals, different types of cables.
ClassicYotas
Post by ClassicYotas » Sat Dec 12, 2015 9:05 pm
As the title says, I have a Mondo that I bought specifically to power all of my pedals. I really dont want to buy another power supply, and I think the MONDO will suffice.
I have shopped the voodoo lab accessories tab. Can someone please make sure I am buying the right cables so that I can safely power all of the pedals with no hum?
Thank you! All help is appreciated.
List of pedals & matching cables:
1x 3.5mm - 1/8” Mini Plug (right-angle) : Proco rat
3x: 5.5mm x 2.1mm “White” Barrel – Reverse Polarity (straight) : Moogs (Ring mod, MURF, Cluster Flux)
1x: .5mm x 2.5mm “Red” Barrel (right-angle): Line 6 FM4
1x: PPAC Only - 5.5mm x 2.5mm Dual “Red” Barrel (straight): Digitech Whammy 4
9X 5.5mm x 2.1mm Standard Center Negative (straight):
*Polytune tuner
* MXR Distortion +
*ZVex Mastotron
*Dunlop 535Q Crybaby
*Strymon Timeline
*Strymon Bluesky
*Strymon Lex
*Digitech Hardwire RV-5
*EHX Super Pulsar (which will probably be replaced by a Fulltone Supatrem)
Im aware I have a outlet on the back of the MONDO. I am willing to use it if I need too.
Also, these cables add up. Is it possible to buy one cable that has multiple 9X 5.5mm x 2.1mm Standard Center Negative (straight) cables like the ones that come with the voodoo? It would be better than buying them separately I think.
Re: One MONDO to power all 15 Pedals, different types of cab
Post by JohnClark » Tue Dec 15, 2015 11:55 am
The Whammy 4 requires AC power only. It can be powered from the Courtesy Outlet on the back of the Mondo using its included power supply. The cable you mentioned is for use with the Pedal Power AC.
Here is what comes with the Mondo...
5.5x2.1mm right angle barrel connectors (10)
5.5x2.1mm straight barrel connectors (2)
5.5x2.5mm right angle “red” barrel (5)
3.5mm right angle mini plug (1)
9V battery snap (1)
I think the only cables you would need separately are the Reverse Polarity Barrel Cables for the Moogerfooger pedals, and a couple of the Output Splitter Adapters to power two pedals from a single output.
Everything else is covered by the included cables.
ClassicYotas
Post by ClassicYotas » Wed Dec 16, 2015 4:38 pm
Oh Im sorry. I forgot to mention, I lost all of the cables in a move. I have ZERO cables.
Is my current list of cables needed correct? Can I buy a bulk pack of all of the cables that came with the MONDO and then the other cables you mentioned?
Post by JohnClark » Wed Dec 16, 2015 5:18 pm
Oh yea... that would be an important point!
I would suggest giving us a call directly or writing to info@voodoolab.com. Be sure to refer to this thread so you don't have to start all over again. ;)
Rodrijili
Post by Rodrijili » Wed Jan 17, 2018 11:55 am
ClassicYotas wrote:I have a Mondo that I bought specifically to power all of my pedals. I really dont want to buy another power supply, and I think the MONDO will suffice.
Hi ClassicYotas, I'm new in this forum and I've checked you have almost the same pedals as me and also want to buy the Mondo.
I'm worry about 3 moogerfoogers (Ring Modulator, Analog Delay, FreqBox), BlueSky and a Boss ES8, because I bought a custom power supply but I get hum or other noises, I think it's because of the moogs and its high current consumption.
I want to know how did the Mondo go for you?
My pedalboard setup:
Boss - ES8
Boss - Metal Core
Digitech - Whammy 4
Moog - FreqBox
Moog - Ring Modulator
Moog - Analog Delay
Electro Harmonix - Russian Big Muff Pi
Dunlop - Cry Baby Bass
MXR - M87 Bass Compressor
TC Electronic - Ditto Looper
TC Electronic - Polytune
Strymon - BlueSky
ZVex - Fuzz Probe
Thanks in advance!
Rodrigo Narcía
