Ground Control with pedal switcher
VenturaSteve
Post by VenturaSteve » Sun Aug 30, 2015 11:24 am
Hi All
Currently I'm using the Commander on a pedalboard with 2 pedal switcher & an control switcher in a rack next to the amp. But I'm finding that I'm missing the ability to add a pedal to the presets on the commander.
So... would replacing the commander with a ground control be the best approach.
Also, on a separate topic, I'm having trouble posting photos on this site. Any pointers would be great
Thanks !!!
Re: Ground Control with pedal switcher
Post by JohnClark » Mon Aug 31, 2015 10:56 am
A Ground Control Pro would certainly be able to control the switchers and would add the ability to have Instant access buttons to turn individual loops on/off within a preset.
Posting pics requires either uploading the file when you create your post then inserting into the post or hosting them somewhere and linking to them. If you were having trouble uploading the file, did you get some sort of error message?
VenturaSteve
Post by VenturaSteve » Mon Aug 31, 2015 11:10 am
Thanks, for the Ground Control, what I expected. Just confirming
Nice picture, almost lunch time here so that didn't help :-))
But you mention uploading, I see this above the text box.
Does this have something to do with it ?
Tried "copy/paste" between the brackets. That didn't work.
I'm sure it's something simple.
Post by JohnClark » Mon Aug 31, 2015 11:15 am
Heh, sample pic I grabbed to test... but I ate it already before anyone else could see 8-)
After you upload a file new options will appear to post it inline just below the post text box or to add it as an attachment to the post at the bottom of the screen.
VenturaSteve
Post by VenturaSteve » Mon Aug 31, 2015 12:04 pm
Think I figured it out
I'll need to work on sizing the photos 620 x 1200 does not meet most of the photos I have.
