It is currently Fri Feb 23, 2018 3:39 pm
Post new topic Reply to topic  [ 60 posts ]  Go to page Previous  1, 2, 3, 4, 5, 6  Next
PostPosted: Sun Jun 16, 2013 11:46 am
I have a Carl Martin Octa-Switch that needs 9V regulated w/ 400mA...can I use the current doubler on outputs 5 & 6 of my Pedal Power 2 Plus to power it? Should the dip switches be in the NORMAL position?
Currently, I am powering it with a Visual Sounds 1 Spot...which is a complete hassle to thread up under my Pedaltrain every time I play and run to an extension cord.
Thanks. :D
PostPosted: Thu Jun 20, 2013 9:48 pm
Hello, is there anybody here?
PostPosted: Tue Jul 09, 2013 10:18 am
Thanks. :D
Sorry, didn't see you hiding up here.
The Octa-Switch and the Octa-Switch II, actually draw less than 200mA and can be powered directly from output 5 or 6 with the corresponding DIP switch set to Normal using one of the regular barrel cables.
PostPosted: Fri Jul 12, 2013 1:52 am
Thanks for the reply.
I had already ordered the current doubler adapter cable...and tried it and it was very NOISY. I had already found your reply on someone else's post about powering the Octa-Switch...and tried output #5 in the "normal" position on my Pedal Power 2 and YAY, it powered up just fine and quietly!
So, turns out I didn't need this cable after all! ;Debbie
 Post subject: Re: Current Doubler Adapter cable for centre +ve pedal
PostPosted: Sat Jul 19, 2014 1:09 am
Hi
I have an Effectrode Helios fuzz pedal that requires 12VDC @ 350mA (centre +ve) and a PP2+.
Can I use the PP2+ 5 and 6 output in the away from Normal position in a reverse polarity configuration?
Many thanks,
Teddy
PostPosted: Mon Jul 21, 2014 2:58 pm
Teddy59 wrote:
Hi
Many thanks,
Teddy
Until I can get my one on my bench for testing, I wouldn't suggest using anything but the supplied adapter for the Helios. You can plug the supplied adapter into the Courtesy Outlet on the back of the Pedal Power 2+.
PostPosted: Mon Jul 21, 2014 3:13 pm
Hi John I also came to that conclusion too. Better to be safe and sure before trashing my new investment!
All the best Teddy
PostPosted: Mon Jul 28, 2014 12:08 pm
A question about the eventide timefactor- can it power off the courtesy outlet on the PP2+ or has to run with the set up shown in the other thread?
PostPosted: Mon Jul 28, 2014 12:11 pm
Any pedal that comes with an adapter can be powered by connecting the supplied adapter to the Courtesy Outlet.
PostPosted: Mon Aug 25, 2014 5:31 am
What would happen when using the 'current doubler' cable to combine one of the 250ma outputs with one of the 100ma ouputs?
