It is currently Fri May 24, 2013 6:45 pm
 Post subject: phantom power via 5-7 pin style cable
PostPosted: Mon May 07, 2012 10:13 am
Im having a custom stage ready midi cables made in UK for AxeFx2 / GCP rg
need the pin configuration for the GCP - which pins carry the power .. ? ( my gcp from 2002 )
I had intended to use my axefx 2 and its 7 pin to 7pin option but would seem this isnt a direct path + hits the axe's midi board with power from the walwart supply for the GCP ( some users have damaged the board with excessive phantom requirement over 1000ma .. so am going 5pin/power Y cable route back to the GCP ..
cheers in advance ...
 Post subject: Re: phantom power via 5-7 pin style cable
PostPosted: Mon May 07, 2012 2:58 pm
This should help you out...
viewtopic.php?f=9&t=1187&p=3618&
Voodoo Lab ®
Tech/Magician
PostPosted: Fri Aug 10, 2012 8:53 am
Here is a link to a post on the Fractal Forum regarding the Axe-FX 7-Pin MIDI Pinout.
This information, when combined with the info John has already provided, should be enough for whoever is making your stage ready MIDI cables to construct a custom 7-pin cable to run directly from your Axe-FX2 to your GCP.
