It is currently Fri May 24, 2013 11:22 am
[ 3 posts ] |
| Author |
Message |
Casselton
Post subject: Pedal Midi CC numbers / AXE FX II Posted: Tue Mar 06, 2012 8:30 pm |
I want to use Pedals 1 & 2 on the GCP with the Fractal Axe FX. What CC numbers are transmitted by the GCP for Pedal 1 and Pedal 2? FYI - I want to control volume and WAH.
If there is anyone out there with the AXE FXII that has some additional insight, it would be appreciated. I've got everything working except the pedals.
Many thanks
| Top |
Post subject: Re: Pedal Midi CC numbers / AXE FX II Posted: Thu Mar 08, 2012 12:36 pm |
Joined: Tue May 05, 2009 2:33 pm Posts: 3590 Location: The Lab
Both the MIDI Channel (Target Device) and the Control Change message sent are programmable for each preset on the Ground Control Pro. Look to the Using Expression Pedals section of the Ground Control Pro manual under Edit Preset for information on how to set them to control whatever you want.
 Voodoo Lab ® Tech/Magician
| Top |
Casselton
Post subject: Re: Pedal Midi CC numbers / AXE FX II Posted: Fri Mar 09, 2012 9:13 am |
Thanks for the help. Problem solved. Casselton
| Top |
[ 3 posts ] |
Who is online |
Users browsing this forum: Bing [Bot], Google [Bot] and 0 guests |
