It is currently Fri May 24, 2013 2:31 am
 Post subject: GCX, GCP and G string
PostPosted: Fri Jan 27, 2012 4:05 pm
Could anyone possibly help me? I'm struggling with connecting my rack. I have a GCX and GCP with an AKG wireless, Behringer BTR 2000 tuner, ISP Decimator G-string, BD-2 Blues Driver, CS-2 Compressor/Sustainer and a TC G major 2 going into a Fender Blues Deluxe Reissue, on which I'd like to use the GCP to switch channels and reverb if possible.
I have used a ream of paper printing out the blank schematics and trying to work out the best way of connecting everything but it changes every time! I think it's the G string that throws me and the manual isn't helping.
A schematic would be really helpful if anyone could spare the time....
Thanks in anticipation...
 Post subject: Re: GCX, GCP and G string
PostPosted: Tue Feb 07, 2012 12:42 pm
The G-String will be connected in multiple places. First you will want to route the dry guitar signal to its Guitar In. This can come from the output of your wireless. The G-String Guitar Out will feed your first GCX Loop In. After that you will route all the front end effects as normal and anything that will be in the effects loop. Here is a sample diagram that shows the connections you would likely need except for running the wireless and G-String as described above.
http://www.voodoolab.com/gcxdiagrams/01 ... _AmpSw.pdf
Where in the signal chain do you want to run the actual noise gate portion (The DEC In and DEC Out) of the G-String? Do you want to run the gate portion in a GCX Loop?
For the channel and reverb switching, your connections will be the same except that you will need a custom made Y Cable. Here is a thread on the topic with a description of the necessary cable.
viewtopic.php?f=9&t=3439
Voodoo Lab ®
Tech/Magician
