It is currently Mon May 20, 2013 1:14 am
[ 2 posts ] |
| Author |
Message |
LEONARDPAUL
Post subject: Problem with my ISP DECIMATOR Posted: Wed Jan 11, 2012 3:52 am |
Hi ! I've got a problem with my ISP DECIMATOR. It's center negative and can be powered with a 9V battery or with an 9V adapter of at least 100 mA. I try to connect it to my voodoo PP2. I got a polarity converter(see picture). It doesn't work ! Please, help me. Thanks.
| Top |
Post subject: Re: Problem with my ISP DECIMATOR Posted: Wed Jan 11, 2012 12:54 pm |
Joined: Tue May 05, 2009 2:33 pm Posts: 3588 Location: The Lab
The picture didn't load, but it probably isn't necessary...
The Pedal Power 2 outputs are all Center Negative. To power the Decimator pedal, you would simply use one of the included standard all black barrel cables from any of the outputs on a Pedal Power 2 with the corresponding DIP switch set to Normal.
 Voodoo Lab ® Tech/Magician
| Top |
[ 2 posts ] |
Who is online |
Users browsing this forum: No registered users and 1 guest |
