It is currently Fri May 25, 2018 1:58 am
 Post subject: PX-8 set up with NS-2 Noise Suppressor
PostPosted: Wed Apr 11, 2018 10:38 am
Hi. I am new to this forum. I am completely new to some of this pedal loops and switch gear. I am not sure if this has been previously been answered.
I just got my PX-8. I am using a Boss with about 10 pedals including a tuner. I use the advanced set up with the NS-2. NS-2.GUITAR >> NS-2 INPUT NS-2 SEND >> Amplifier INPUT Amplifier FX SEND >> NS-2 RETURN NS-2 OUTPUT >> Amplifier FX Return
What is the best method for connecting the NS-2 to the PX-8? I also run two amps using a Radial ABY amp switcher. What is the best set up for this gear? I appreciate responses very much.
 Post subject: Re: PX-8 set up with NS-2 Noise Suppressor
PostPosted: Wed Apr 11, 2018 11:36 am
You will probably still connect the NS-2 directly as you've detailed. However, I'm not sure exactly how you'd go about using the NS-2 in this manner when using two amps... do both amps have effects loops? Do you strictly A/B between them or do you ever run both amps at once?
Where do you run your effects currently?
PostPosted: Wed Apr 11, 2018 9:27 pm
Thank you for your reply. Apologies for not being more detailed in my question. I only use the effects loop in amp 1. I am using an ABY switch. 2 amps are on at the same time. The NS-2 runs through all of the pedals. I use the input-output-send-return on the NS-2.
So
NS-2>Pedals>ABY>Amp 1 input and effects loop>Amp 2 input.
I appreciate feedback.
PostPosted: Thu Apr 12, 2018 11:50 am
So all your effects are in front of the amps, with no effects in the FX Loop of amp #1?
If so, I'd say the PX-8 would most likely go between the NS-2 Send, and ABY Input.
What is the noise that you are killing with the NS-2 anyway?
PostPosted: Sat Apr 14, 2018 12:07 am
I've been out. Thanks for the reply John. I've been playing around with the PX-8 Plus. I must say I a impressed with it. I took out the suppressor.
To clarify. Typically in front of amp 1 - overdrive > fuzz > eq. In back (FX Loop) Chorus/Delay/Trem/Reverb. Ill throw a flanger in there too at times. Any suggestions about placement in the PX-8 Plus? Loops 1-6 to control the FX Loop effects, 7-8 drives and fuzz?
Thanks.
Users browsing this forum: Bing [Bot], Google [Bot] and 3 guests
