Control Switcher V1 not remembering settings
Just Mike
Post by Just Mike » Sat Mar 31, 2018 4:27 pm
I can get it to respond to PC messages and I can set the switch presets. I can cycle thru the PC commands and all is good. I can reboot the GT-10 that's sending the PC messages and it works, but when I power cycle the Control Switcher, I lose the presets. Am I (or the V1 "preliminary" manual) missing a "save" step?
Re: Control Switcher V1 not remembering settings
Post by JohnClark » Tue Apr 03, 2018 12:41 pm
Saving presets should be done by pressing buttons 1 and 4 at the same time after sending a Program Change. The LEDs should all flash to confirm the save.
Saved presets should absolutely stay in memory after power down.
If you can give us a call while you are with the gear, we should be able to get it sorted out pretty quickly.
