GCX AUDIO SWITCHER GCP TROUBLESHOOT
GabiRodz01
Post by GabiRodz01 » Mon Mar 26, 2018 6:30 pm
Hi!
Recently bought a GCX and GCP combo and when I connected the system, as I pressed the #3 switch on the GCP it activated the LOOP 5 on the GCX. When I pressed the #5 switch on the GCP, LOOP 5 on the GCX stayed on. When I pressed the #3 switch again, it deactivated LOOP 5 on the GCX. The LOOP 3 does not activate when I press the #3 switch on tge GCP. What could this be?
Re: GCX AUDIO SWITCHER GCP TROUBLESHOOT
Post by JohnClark » Tue Apr 03, 2018 12:31 pm
It sounds to me that the Ground Control Pro... the "Programmable MIDI Controller" ;) ...has simply been programmed to do exactly this. Were these purchased new or were they previously owned?
Do you have the Ground Control Pro in 4 Presets per Bank mode with the eight Instant Access buttons or is it in 10 Presets per Bank mode?
