Px8 plus
cesarparedesm
Px8 plus
Post by cesarparedesm » Mon Mar 12, 2018 5:50 pm
Hi, I just bought a px8 plus. I have some questions about the connection of pedals to my new device. I used to connect some pedals directly to the input of the amplifier ( wah, compressor, overdrives and distortion ) and others through the effects loop (modulation and delay ). Can you do that with the px8plus?
The other question is with the noise reduction pedal. How do I connect it to the px8?
Thanks for your answer
Re: Px8 plus
Post by JohnClark » Tue Mar 13, 2018 3:45 pm
The Insert on the PX-8 Plus is a way to break up the pedal loops. For instance, you can use loops 1-6 for your front end effects, and use Loops 7 and 8 for your FX Loop effects.
Noise reduction pedal... This may be a trick question, but do you need it? ;) (basically, whats making noise?) Exactly which model pedal is it? Is it on at all times, or do you need to turn it off sometimes?
