Stiff 90-AD amp channel switching & effects loop on/off
Hamer95USA
Post by Hamer95USA » Mon Feb 05, 2018 10:44 am
Hello Voodoo Lab,
I have a Zoom G9.2tt floor processor and a Voodoo Lab control switcher. I recently bought a Stiff 90-AD amp head and would like to switch the amp channels between clean & overdrive and the effects loop on/off. The stock footswitch uses a stereo cable to allow for switching. My MIDI signal path is Zoom MIDI out > Voodoo Lab Control Switcher MIDI input.
Would I be able to use the stereo cable with the Control Switcher to switch amp channels and turn the effects loop on/off or would I need a 1/4" TRS male jack to TS male Y cable to access the amp's channel switching and effects loop on/off functions? Would I need to have a custom DIN cable built for me from Voodoo Labs? Your information would be greatly appreciated.
Re: Stiff 90-AD amp channel switching & effects loop on/off
Post by JohnClark » Mon Feb 05, 2018 1:50 pm
For that amp you would need an Insert Point cable. (One TRS end that breaks out to Two TS ends.)
Hamer95USA
Post by Hamer95USA » Mon Feb 05, 2018 10:22 pm
Thanks for replying to my thread in a timely manner and the useful advice. I appreciate your technical information on this forum.
Guitar George
