It is currently Wed May 23, 2018 11:43 am
 Post subject: power adaptor and phantom power at the same time
PostPosted: Sun Jan 21, 2018 7:43 am
Hi John,
I was wondering, whether I can safely use a 5 pin MIDI cable between a HEX and a Control Switcher when both HEX and Control Switcher also receive power via their individual barrel connectors at the same time.
The chain is Commander -> Control Switcher -> HEX
I know I could use the jumpers inside the Control Switcher and power everything from HEX (I asked about that before), but I just want to know if I have to be careful when I use a 5 pin MIDI cable if I am ever going to power HEX and Control Switcher individually.
On a more general note, are there any other devices where I would have to be careful (e.g. wall wart and phantom power for a Ground Control Pro)?
Thanks in advance!
 Post subject: Re: power adaptor and phantom power at the same time
PostPosted: Wed Jan 31, 2018 3:57 pm
This should be a perfectly safe setup, powering both the Hex and the Control Switcher. No problemo!
As for the Ground Control Pro, I wouldn't send it both Phantom Power and connect a power adapter... not gonna break it, but it will generate unnecessary heat inside the controller.
Users browsing this forum: Bing [Bot] and 7 guests
