amp switching
mindbenderzzz
amp switching
Post by mindbenderzzz » Sat Jan 20, 2018 10:47 am
is it possible to run several preamps through a GCX to a main power amp and just make the GCX into an amp switcher or is it not designed to handle that type of signal
just a though or is it a pipe dream
nyteowl
Re: amp switching
Post by nyteowl » Mon Jan 22, 2018 12:29 pm
mindbenderzzz wrote:is it possible to run several preamps through a GCX to a main power amp and just make the GCX into an amp switcher or is it not designed to handle that type of signal
All depends on your definition of several.
This topic seemed familiar, so I did a forum search and found an old thread about running 2 preamps into a single power amp.
Between the info in that thread, and the routing diagram I referenced on the GCX product page, hopefully you can expand on everything and come up with a viable way to route your signal.
mindbenderzzz
Re: amp switching
Post by mindbenderzzz » Mon Jan 22, 2018 2:43 pm
this was helpful thank you
