Tecnical data and block diagram about the amp selector
fatboy135
Post by fatboy135 » Mon Nov 16, 2009 3:06 pm
Hi everybody, new voodoo lab owner here.
I just purchased an amp selector to split the signal of the bass through 5 different audio pro preamps to record the signal directly to my daw. Some of the preamps have a high input impedance ( near 1 Mohm ) and other a not so high input impedance ( near 40 Kohm )
For that reason I need some info about the amp selector:
- Input impedance
- Output impedance of each of the 4 trafo isolated outputs
- Output impedance of the non isolated output
- Block diagram to see how is connected in cascade the solid state input buffer and the trafos outputs
Thanks to all and best wishes
Josh Fiden
Site Admin
Re: Tecnical data and block diagram about the amp selector
Post by Josh Fiden » Tue Nov 17, 2009 12:58 pm
fatboy135 wrote:Hi everybody, new voodoo lab owner here.
- Input impedance
The input impedance is 1M. Every output is easily capable of driving a 40K load.
Regards,
Josh Fiden
Founder / CEO
fatboy135
Post by fatboy135 » Tue Nov 17, 2009 3:13 pm
Good
ok so I understand that the buffer and the transformers are calculated to not surrender with that load impedance, but what is exactly the output impedaces??? are them a high z like 1 Mohm or maybe a medium z like 100 Kohms???
and what about the direct output for the tuner??? are this output thought for connect it for high z input amps or maybe for lower impedances as mic/line devices????
thanks for your support
Josh Fiden
Site Admin
Post by Josh Fiden » Tue Nov 17, 2009 4:42 pm
I see that you don't understand what impedance means, so further technical details will not be helpful.
Are you having a problem? What are you trying to find out?
Regards,
Josh Fiden
Founder / CEO
