It is currently Thu Jul 19, 2018 2:32 pm
Post new topic Reply to topic  [ 10 posts ]
 Post subject: GCX buzzing noise with pedals
PostPosted: Mon Apr 03, 2017 1:44 pm
i noticed that when i have any pedal patched in to the gcx and powered with a 1 Spot daisy chain, even if it's just 1 pedal at a time, a buzzing noise comes thru the system and out my speakers when i play...unpatch the pedal and it goes away..any pedal...thoughts? if i get a pedal power will this problem go away?
 Post subject: Re: GCX buzzing noise with pedals
PostPosted: Mon Apr 03, 2017 2:00 pm
Do the same pedals make noise when powered via batteries and connected to the GCX loops?
PostPosted: Mon Apr 03, 2017 2:21 pm
i will try that tonight when i get home from work.
PostPosted: Mon Apr 03, 2017 7:30 pm
Put a battery in a pedal and the buzz went away..thoughts john?
PostPosted: Tue Apr 04, 2017 2:03 am
What is the pedal causing the noise? It's pretty common when you daisy chain your pedals with OneSpot and don't use isolated outputs from a power suply.
Some pedals don't react the same in conjuction with other when you daisy chain them...
PostPosted: Tue Apr 04, 2017 6:07 am
any pedal that i put in any loop
PostPosted: Tue Apr 04, 2017 9:25 am
It is interesting that you are getting this problem when powering only a single pedal. that it goes away when using a battery certainly shows its some sort of interaction between the power supply and the GCX. Does the noise stay constant or does it only happen when the GCX loop for the powered pedal is active?
PostPosted: Tue Apr 04, 2017 9:41 am
The noise is constant whether the loop is on or not...my testing was with the loop not active...do i need something like a pedal power 2?
I would also like to add that the noise issue exists even when not using the 1 spot and using my eventide H9 with it's own power adapter....
My gcx is an old one back from the Digital Music Corp days
PostPosted: Tue Apr 04, 2017 11:22 am
I am unsure exactly what you are experiencing here so I cannot say if a Pedal Power will make the difference.
Are you plugging right into the loop for testing or are you using the Guitar In/Out jacks in front of the loop? If you have tried both, is there any difference between the two routings?
PostPosted: Tue Apr 18, 2017 12:52 pm
I bought a trutone 1 spot pro and it fixed my issue...isolated power with a 3 prong power cable, not a two prong wall wart type
